1991 Ford Probe Gear Shift Stuck in Park
JSCOTT96
1991 Ford Probe w/ 173000 miles. Went to leave this morning and couldn't disengage the gear shift from PARK down to REVERSE to leave. I've had somewhat similar problems in the past, usually resolved by fiddling with the piece of plastic at the base of the gear shift, just to the right of it. Tried that w/ no success, but while my wife pressed on the brake, turned the steering wheel, and tried to shift, I pushed up and down, and forward and backwards, on the back of the car and was able to get it disengaged. Of course when I got to work I impulsively put it into PARK, and now its stuck there again, this time not budging despite my "shaking" efforts.
Any thoughts? The loose piece of plastic at the base of the gear shift now appears even more dislodged and I can't figure out what this thing does and if its getting in the way of changing gears.
Would love to avoid a trip to the mechanic, but thanks in advance for any help. :?
Jan 4, 2006 at 6:25 PM
GODBEAR839
  • 77 POSTS
Tear the whole console out not sure if your year/model has it but most have a keyed lock to stop it from being shifted i be this part is broken and has fallen over to the locked position the best thing is to remove the whole console. Do it slow and bring a jar for all the screws take your time and all you really need is a pair of needle nose pliers and one short and one very long phillips drivers to open the console up. the pliers are for any dropped screws.
Jan 6, 2006 at 7:25 AM
Suggested Repair
Carefully remove the center console to inspect the shift interlock. A keyed shift-lock mechanism may be broken and stuck in the locked position. Work slowly, keep all screws organized, and use needle-nose pliers plus short and long Phillips drivers.
Conversation Summary
A 1991 Ford Probe with high mileage is stuck in Park and will not shift into Reverse. Similar past issues were sometimes freed by moving a loose plastic piece at the base of the shifter, and rocking the car once released it, but it is stuck again and the plastic piece looks more dislodged. The expert advises removing the console to check a likely broken keyed shift lock that has fallen into the locked position, using basic hand tools and keeping track of the screws.
