1991 Ford Probe Fuel System
110,000 MILES • 6 CYL • FWD • AUTOMATIC
VZDAVIS
Car won't start. It would run for about 3 mins & then shut off. It wants to turn over but it won't. Have checked: fuel pump has been replaced. Fuel is coming thru just no spark. Will be changing the distributor, coil, & rotor tomorrow. Do you think that may be the problem?
Feb 4, 2010 at 2:43 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 4, 2010 at 3:21 PM
