1991 Ford Probe Bleeding the brakes
ANDYSENES
Brakes problem
1991 Ford Probe Two Wheel Drive Manual
my brakes are spongy, & i'm going to replace the pads, front & back. i think there's an airlock/ airlock's,in the front system. i'm going to top up the brake fluid & need to know how to bleed the system. thank's y'all
andysenes
May 21, 2008 at 3:29 AM
BLACKOP555
  • 10,386 POSTS
rear right, rear left, front right and front left is the proper sequence for bleeding the brakes. have a friend help you pump the brakes and also make sure the fluid level stays as high as it can be when your bleeding the brakes.
May 21, 2008 at 5:14 AM
