1990 Ford Probe HeadLights
175,000 MILES • 4 CYL • 2WD • AUTOMATIC
CLASKEY
When we bought this car a few months ago the lights where dim. So we drove with the high beams on. Now when I turn on the lights the drivers side only comes on then when I turn on the high beams only the passenger side works. I told you about the dim lights because I don't know if the problem is linked. It seems a bit funny both sides would go bad at the same time.
Dec 26, 2008 at 2:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
First thing you should do is to check your bulbs. Could simply need replaced. Easiest and cheapest place to start troubleshooting.
Thanks for using 2carpros.com!
Dec 26, 2008 at 5:39 PM
