Where is the fuel pump relay located on a 90 Ford Probe ?
Jan 22, 2010 at 9:04 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
BLUELIGHTNIN6
CAR REPAIR CONTRIBUTOR
fuel pump relay on the Probe is located on the interior relay block (behind left kick panel)
if not getting fuel then also check the inertia (fuel cut off) switch located behind left rear interior trim panel
