1990 Ford Probe fuel pump relay
144,000 MILES • 6 CYL • FWD • MANUAL
WICKEDSMILE
Where is the fuel pump relay located on a 90 Ford Probe ?
Jan 22, 2010 at 1:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
fuel pump relay on the Probe is located on the interior relay block (behind left kick panel)
if not getting fuel then also check the inertia (fuel cut off) switch located behind left rear interior trim panel
Jan 22, 2010 at 1:11 PM
