1990 Ford Probe ecu
SOILBORN
Computer problem
1990 Ford Probe 4 cyl Two Wheel Drive Manual tomuch miles
hi i was wondering is possiable to swap out a 2.2l 4 cyl non turbo engine wiring harness with a 2.2l turbo wiring harness with out the turbo just run it for the biigger injectors with out the ecu reflash confusion?
Aug 23, 2009 at 10:58 AM
  • 31,937 POSTS
Hi there,
I feel that this will not work as you wish, as i am sure that the TPI and air flow calibrations will be different, i feel that it will run far to rich.
Mark (mhpautos)
Aug 23, 2009 at 5:51 PM
