1989 Ford Probe `water pump
LILJENNI13
1989 Ford Probe 4 cyl Two Wheel Drive Automatic
how do you install the waterpump?
Nov 2, 2008 at 8:18 AM
RAYBURN 13
  • 5 POSTS
well first you will have to drain all your fliud out of the rat. and then. take off the timing belt cover. take off the alt. belt and move the alt. out of the way to. then you will have to look at the little timing marks on the cam and on the crank make sure you put them arrows to the marks and DONT LET THEM MOVE. take off the timing belt. then take out the 6 bolts that hold the water pump on and then make sure you clean the block off to get the old gasket off.. then put water pump gasket on and then the pump and then put the timing belt back on but MAKE SURE YOUR TIMING MARK ARE IN THE RIGHT SPOT... (A MOST OR SAY BY BY VALVES) put back on the alt belt and then the timing cover. and then fill the rat. back up and your good to go. I just did this in my mazda 6 same thing took me 45 mins to do it...
Dec 3, 2008 at 6:00 AM
