1989 Ford Probe Timing on non-running engine
1989 FORD PROBE
103,000 MILES • 4 CYL • FWD • AUTOMATIC
MB700000
  • 6 POSTS
Can timing be checked on an engine that won't run?
Jul 14, 2009 at 12:19 PM
You can do a static timing on it by placing no.1 piston on its compression stroke and lining up the timing marks at the pulley to 0/TDC and make sure the rotor is pointing to the no.1 cap tower. At this point the car should fire up and then use an inductive timing light and set it to specs.
Jul 14, 2009 at 12:33 PM
