1989 Ford Probe the vehical shakes in gear
200,650 MILES • 6 CYL • FWD • AUTOMATIC
PAPPALARDO
the car runs great for how old it is . starts up every time with no problem.idles in park and neutral just like normal. when i put it in gear it shakes, alot. untill i give it gas, i know i cant adjust the throttle. so it says on the hood. just when im stopped it rattles could this be a motor mount? or what do you think?
Apr 28, 2008 at 4:40 PM
RENOTS
  • 8 POSTS
[quote:86a212291a="pappalardo"]Shakes or Wobbles problem
1989 Ford Probe 6 cyl Front Wheel Drive Automatic 200650 miles
the car runs great for how old it is . starts up every time with no problem.idles in park and neutral just like normal. when i put it in gear it shakes, alot. untill i give it gas, i know i cant adjust the throttle. so it says on the hood. just when im stopped it rattles could this be a motor mount? or what do you think?[/quote:86a212291a] something with trans i for got what its calld but when stoped at a light in gear it makes a auto trans go like in nutrale but when it dont work car shakes becuse it is trying to go you could pay to fix i recomend a new trans it will be cheper
May 21, 2008 at 8:03 PM
