Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Probe
Drivetrain
Transmission
Gear Position Sensor
1989 Ford Probe neutral switch
1989 FORD PROBE
189,000 MILES • 6 CYL • FWD • AUTOMATIC
NELSONV
MEMBER
1 POST
how do i reset the neutral switch,car shuts off on drive but not on reverse.
Oct 6, 2009 at 10:18 AM
Experienced Mechanic
The neutral safety switch has nothing to do with the engine stalling when put on drive-Your problem is coming from somewhere else-
Might want to clean out the idle air control valve, and test the TPS and MAF sensors for a start to include checking the ignition timing.
Oct 6, 2009 at 10:48 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
