1989 Ford Probe Lights
CANUHLP
  • 7 POSTS
Electrical problem
1989 Ford Probe Manual 141000 miles
My reverse lights stay on all the time.
started with gear shift in drive then it is now on when the car is in neutral
can u please help me
Jul 31, 2009 at 4:46 PM
JDL
  • 16,098 POSTS
Hello, take a look at the neutral switch, may need to adjust the shift cable.
Aug 1, 2009 at 4:23 AM
CANUHLP
  • 7 POSTS
[quote:66e62f49d1="jdl123"]Hello, take a look at the neutral switch, may need to adjust the shift cable.[/quote:66e62f49d1]
Where can i find instructions on how to look at the neutral switch as well as adjust the shift cable?
please if you dont mind or even where i can find it online.
Aug 1, 2009 at 6:23 AM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_ford_probe_1.jpg
My bad, I don't know why I thought you had an automatic, it says manual on your post. Check the back-up light switch. Below is the partsbook picture.
https://images.2carpros.com/forum/automotive_pictures/170934_probe_backup_light_switch_1.jpg
Aug 1, 2009 at 7:41 AM
CANUHLP
  • 7 POSTS
i thank you very much for responding so quickly for i am eagarly awaiting your replys
But as far as the pic u sent where am i suppose to find that?
By the way did tht pic come from something that i am able to see online i tried to find a free online manual for 1989 ford probe turbo with no success
please forgive me for the novice knowledge regarding this problem i am a female in training
laughing to myself :)
thank you again for your help
Aug 1, 2009 at 7:47 AM
JDL
  • 16,098 POSTS
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
I don't know if the above link will work, it came from the site. I don't have a good picture of the location. I'd look at the bottom of the transaxle or close to the bottom.
Aug 1, 2009 at 8:02 AM
CANUHLP
  • 7 POSTS
[quote:8432fee6c3="jdl123"]http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?fromSearchPage=true&pageId=0900c1528004541c&partName=Back-up+Light+Switch&partId=0900c1528004541c
I don't know if the above link will work, it came from the autozone site. I don't have a good picture of the location. I'd look at the bottom of the transaxle or close to the bottom.[/quote:8432fee6c3]
I got to the site i had to do alot of leg work cause i knew i had an acct w/ autozone so im in now ill take a look and get back with you if i have other questions which i probably will :)
If you do not mind sir
thank you so very much :)
Aug 1, 2009 at 9:06 AM
