1989 Ford Probe Headlight Motor
144,000 MILES • 4 CYL • FWD • MANUAL
TOPGOALKEEPER
The right headlight became stuck about halfway in travel between deployed and retracted when the lights were turned off. The next morning the car would not start. When the light would not retract that night (the drivers side DID retract), I checked to make sure that the light had actually switched off- it did. Is it possible that the light motor is stuck in an 'open' position, and draining my battery?
Also, I have tried to use my Haynes manual to try to disconnect the lamp motor to prevent the battery drain, but the instructions are extremely vague as to where to make the disconnection. I can see the connection between the light motor and the light, but I can't disconnect the coupling as the space for my hands is limited.
Long story short- what is the simplest way to disconnect the faulty light to get to the shop to fix it?
Mar 31, 2009 at 3:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Just remove the fuse and/or relay for the headlights..
Thanks for using 2CarPros.com!
Mar 31, 2009 at 5:33 PM
