1989 Ford Probe fuel pump relays
20,000 MILES • 4 CYL • 2WD • MANUAL
STEVE PHILPOTT
i need to know how many relays there are for the fuel pump and where are they located
Feb 8, 2008 at 3:49 AM
2CARPRO JACK
  • 11,533 POSTS
There is one relay for the fuel pump. Interior relay block drivers side under dash. Lower left relay (usually green, but not always). There is also 2 EFI relays int he underhood relay center ( two leftmost relays as looking at relay block). There is a fuel pump inertia switch located behind the left interior liftgate area trim panel, be sure it hasnt been tripped by pushing the reset button on top
Feb 9, 2008 at 12:22 AM
