1989 Ford Probe fuel pump
212,000 MILES • 4 CYL • FWD • MANUAL
TOPHER87
alright heres my situation, ive replaced everthing, i mean everything, plugs, wires, cap, rotor, manifold, complete engine rebuild, complete tranny rebuild, new radiator, starter, batter, fans, all fuses and relays, new axels, bushings, brakes, rotors, calipers, fuel system, air ocnditioning, heater core, its been redone professionally from the ground up, what i am having problems with and no one can seem to tell me is im still not getting power to my fuel pump i wanted it wired up stock, but since the car will be used for racing i found an alternative to the problem, i would like to have a secondary manual shutoff switch up front with me and there are approxxomately 6 wires...the first is brown, the second and third are both black with white stripes, the fourth is solid black, the fifth is solid red, adn the last is solid black, i need to know which one is positive and which one is negative so i can have it wired to a toggle switch in the dash, also which one of those wires if any would need to be grounded to the car...?
Nov 23, 2008 at 5:02 AM
RAYBURN 13
  • 5 POSTS
where are you gonna race this car????
Dec 4, 2008 at 7:01 AM
