1989 Ford Probe dash lights out
JENINE GALLEGOS
Electrical problem
1989 Ford Probe 4 cyl Two Wheel Drive Automatic
The dash lights went out in my car. How do I fix that?
I have already checked all the fuses.
Nov 20, 2008 at 3:39 AM
DAVE H
  • 13,383 POSTS
check your getting 12v supply to the fuse ??
INSTRUMENT CLUSTER SUPPLY CHECK
Check for 11-13 volts on Black/Yellow wire at instrument cluster 18-pin connector. See INSTRUMENT CLUSTER 18-PIN TERMINAL IDENTIFICATION illustration. 18-pin connector is located on right side of dash, near steering column.
Observe voltmeter reading. If voltmeter reads 11-13 volts, go to INSTRUMENT CLUSTER GROUND CHECK. If voltmeter does not read 11-13 volts repair Black/Yellow wire between gauges and fuse panel.
Nov 20, 2008 at 4:14 AM
