1989 Ford Probe charging system
189,000 MILES • 4 CYL • FWD • AUTOMATIC
AZDIRTRACER
i have a problem somewhere in my charging system. i have replaced the battery and alternator and still not charging. the voltage at the battery when the car is running is only 12.8 volts(when it actually charges) i have checked all fuses and am at a loss for what else i can check. any ideas?
Dec 25, 2009 at 9:17 AM
  • 75,988 POSTS
Get the alternator bench tested if its producing the correct output
Dec 25, 2009 at 9:23 AM
AZDIRTRACER
i had the alternator tested and everything came out good. any other ideas?
Dec 27, 2009 at 7:13 AM
  • 75,988 POSTS
Next step is to check the wiring all the way back to the key and charge indicator.
BTW do you have an external voltage regulator?
Dec 27, 2009 at 7:15 AM
AZDIRTRACER
alright i will have to have fun with the wiring.
and i do not belive so i haven't been able to find one
Dec 28, 2009 at 11:51 AM
