1989 Ford Probe Car stalls
RYANHALL
  • 1989 FORD PROBE
  • 4 CYL
  • FWD
  • 140,000 MILES
Why would my car stall after a cold start. It will run for a bit, then at a stop light, the tach will die, and give it gas it start dying. Checked the fuel filter and it was fine. Could it be computer or coil?
Sunday, February 28th, 2010 AT 8:52 PM
  • 110,182 POSTS
Has the check engine light come on? Have you checked for vacuum leaks? Does it only do it when it is cold?
Monday, March 8th, 2010 AT 3:24 PM
RYANHALL
Check engine light comes on when engine dies. Cant check for vacuum as the car will not start now.
Monday, March 8th, 2010 AT 7:21 PM
