1989 Ford Probe attempted R12 conversion
129,000 MILES • 4 CYL • FWD • MANUAL
MARKISBOSS
Conversion attempted. Gauge reads 60+ lbs on low side but compressor still wont start. Fuse is good as pulling fuse makes cooling fan and blower stop. Didnt know it would do that but I am sure the circuitry hasnt been altered. What am I missing?
Aug 9, 2009 at 1:15 PM
BILLYMAC
  • 2,204 POSTS
Hi check the low pressure switch, this is mounted on the aluminum tank mounted to your firewall. bypass this switch with a jumper wire or paper clip. comp should run if so low on freon or bad switch.
Billymac
Aug 25, 2009 at 11:28 AM
