1989 Ford Pinto oil pressure
78,000 MILES • 4 CYL • 2WD • MANUAL
REGGIE1973
HAVE A FORD 2L OHC SIERRA PINTO 1989 IN A KITCAR. AT HIGH REVS OIL COMES OUT OF THE ROCKER COVER (OIL CAP). I HAVE CHANGED THE CAP AND THE BREATHER IN THE CRANKCASE IS OPERATING OK ANY SUGGESTIONS WHATS WRONG?
Mar 23, 2010 at 1:54 AM
HMAC300
  • 48,601 POSTS
check to see i your pcv system is workng. If i remember right those connect to the cap. the hose could be blocked or where it connects as well as the pcv valve being bad. If not have a dry and wet compression test done on your engine....
Mar 28, 2010 at 12:27 PM
