1978 Ford Pinto car only runs while cranking ignition
7,000 MILES • 4 CYL • 2WD • MANUAL
GEOFF104
I have a replica of a 1953 MG TD. It is built on a 1978 ford pinto chassis and 2.3 lima engine. I have a problem which I believe is electrical. While cranking the ignition the car will fire up. If I keep cranking, It will continue to run. The second I stop cranking the car shuts off immediately.
I cannot figure out the issue. I have replaced the ballast resistor, ignition module, starter coil, and the starter for good measure. I tried to start it again and same thing. Any help would be very much appreciated.
Regards,
Geoff
Mar 25, 2010 at 1:18 PM
BMRFIXIT
  • 19,053 POSTS
What about the ignition switch
I would suspect and check ignition switch
but with key on it should supply power to coil and others
Mar 25, 2010 at 2:17 PM
GEOFF104
Yeah, I'm gonna try that next. I guess other than that all that is left is the distributor?
Mar 25, 2010 at 3:23 PM
BMRFIXIT
  • 19,053 POSTS
check for power at the coil with key on and with key cranking
good luck
Mar 25, 2010 at 11:09 PM
