1996 Ford P100 start problem
ROGERJP
Engine Mechanical problem
1996 Ford P100 4 cyl Two Wheel Drive Manual
just replaced cylinder head and cam after the belt snaped and camshaft broke. but it will not start of the key i do suspect it to be the timming,my problemn is this when you turn the key even from cold it seems to be presurizing the water straight away that it comes straight back out the expansion bottle has any one got any idea as never come accross this befor.
Jan 30, 2010 at 12:17 AM
  • 75,988 POSTS
Hi rogerjp Welcome to 2carpros and TY for the donation-
Combustion leakage:
Did you have the head magnafluxed-sounds like blown headgasket, cracked head or block-Get it block and pressure tested.
Jan 30, 2010 at 12:37 AM
