why is my brake pedal so spongy?????
FORD
CMORE413
I have a 2004 Ford Sport Trac we have replaced the master cylinder, front pads and rotors, check for leaks everywhere. the car stops but the pedal is very spongy. Local shop cant come up with the cause any ideas
Feb 17, 2006 at 12:01 AM
PEPPERMRJ
  • 1,158 POSTS
Bleeding ford brakes can be a PITA. I have had to remove the front calipers and then bleed them to get all the air out of them. Also try adjusting the rear brakes up as much as possible. It helps.
Good luck and let us know. :)
Feb 17, 2006 at 4:32 AM
