water pump and power steering pump leak
FORD
RICO7298
My 93 t-bird 5.0 is leaking coolant through the base where the water pump is sitting on is small but is leaking. Could I put a sealer in the radiator to fix it or not? And My steering pump is leaking under the piece that sticks out of the reservoir in which the hose connects and the sensor connects. Could I fix that or do I have to buy a new pump?
Nov 16, 2006 at 4:55 AM
CATCH_15
  • 250 POSTS
If the water pump is leaking, go ahead and replace it and save yourself problems down the road. Is the power steering pump itself leaking or just one of the hoses leaving it?
Nov 16, 2006 at 6:34 AM
