Transmission
FORD
BLUEFIN2003
I have a 1992 Ford Exploerer 4.0 litre engine , 248000km
In the last few days the transmisson fluid gets really hot and it comes out in the front where the torque converter is located. There is nothing wrong with the radiator it't not clogged up. I was wondering what the problem could be. Thanks for your help. bluefin2003
Jan 22, 2007 at 9:07 AM
MIKE H R
  • 3,094 POSTS
does it leak all the time or only when it get hot? suggest having the transmssion flushed and change the filter. there are shops around like guick lube that fliushes the transmission. if it does not leak all the time it might be that the transmission fluid is building up pressure from overheating
Jan 25, 2007 at 11:25 AM
MATHIASO
  • 1,209 POSTS
you have transmission fluid leak. check the fluid level and have it fixed.
Jan 27, 2007 at 10:17 AM
