Power Window
FORD
DURBAN9288
My power window will go down with no problem, but will not go back up at all. I replaced the the whole switch and still the same problem. I dont think it is the motor because when I use a jumper back to get the window back up, it has no problems at all. Thank You
Jul 31, 2006 at 11:45 AM
MIKEYBDMAN
  • 623 POSTS
[quote:000d296923="durban9288"]My power window will go down with no problem, but will not go back up at all. I replaced the the whole switch and still the same problem. I dont think it is the motor because when I use a jumper back to get the window back up, it has no problems at all. Thank You[/quote:000d296923]
Will need to know year make and model of the vehicle to look at wiring diagram.
Also add more details like which window, how many doors and which switch was replaced.
Jul 31, 2006 at 1:15 PM
