power steering box leaking oil.
FORD
ROBERTS
Hello there,
I have a 1980 Bedford bus (with Isuzu motor) that has done god knows how many miles.
My power steering box is leaking oil.
Any ideas on the possible cause? or how to fix it?
regards,
Robert
Jan 18, 2007 at 4:48 PM
MATHIASO
  • 1,209 POSTS
Do you mean the power steering pump?
Jan 18, 2007 at 10:15 PM
ROBERTS
sorry, yeah, the power steering pump and also the ram.
Robert
Jan 19, 2007 at 7:02 AM
MATHIASO
  • 1,209 POSTS
Leaking seal and worn part required a pump overhaul or replacement.they are usually replaced.However, many times leaking pump can be resealed if an overhaul is elected.Consult the factory manual first for details and proper procedures.
After a repair has been made to the power steering system,bleeding will be necessary to remove trapped air and to obtain a correct fluid level.Refere to the factory manual for bleeding procedures on the specific vehicle being serviced.
Jan 19, 2007 at 9:33 AM
