No heat
FORD
TAKEH2003
  • 5 POSTS
As I was driving in to work the heater seems to be working fine then all of the sudden I don't feel the warm air anymore ( I had the fan on low, temp hi, mix blowing defrost and floor). I then put the fan on high, I can hear the blower but I barely feel any air coming out from the duct with little heat.
Any ideas would help.
Thanks :?:
May 12, 2006 at 2:37 AM
LOSONE
  • 1,616 POSTS
For us to be able to assist you, it is absolutely necessary for you to include the make, model, year and mileage of your car.
May 12, 2006 at 6:43 AM
TAKEH2003
  • 5 POSTS
2003 Ford Ranger, has 47,000 miles
I also have one more question, my air conditioning clutch hup came loose, I bought one from the dealer but they don't have the bolt and the shim kit, I was able to find the bolt but not the shims, are the shim necessery?
May 16, 2006 at 4:00 AM
LOSONE
  • 1,616 POSTS
The A/C clutch when in the off position should have about 1/16 of clearance. You can make this happen with any kind of thin washer. Assemble it and see how much clearance you have.
May 16, 2006 at 5:28 AM
TAKEH2003
  • 5 POSTS
Thanks very much, this really helps
May 17, 2006 at 5:42 AM
