No fuel and no spark!! PLEASE HELP!!!
FORD
99ESCIRTZX2
Thanks for reading and helping me in advance.
Car is '99 Escort ZX2, 2.0l, DOHC, 5spd (cool edition). Essentially, my sister drove the car somewhere, turned it off, went to leave and crank but car spins over. There is no fuel and spark.
What I have done thus far:
1. New coilpack
2. New spark plugs
3. New wires
4. New fuel pump assembly
5. New battery
6. Checked all fuses and replaced questionable ones
7. New PCM
8. New ignition lock cylinder assembly
9. Visually verified that the timing belt is ok and turning both cam gears.
10. Checked inertia switch in trunk, even trip it and pressed it back in.
I can rule out the fuel pump relay since it's in the PCM (and that was replaced).
Before I replaced the ignition switch assembly, when you would turn the key in the "on" position (but not trying to start) the tachometer would bounce up and down. All electrical devices (blower motor, radio) work ok when the key is in the "on" position. One thing that I have noticed is that the relays in the PCM do this erratic ticking (I know relays are supposed to tick but this doesn't sound right) when the key is in the "on" position.
PLEASE help!!
thanks again
EDITED: SUBJECT
Jul 7, 2006 at 6:48 AM
JDL
  • 16,098 POSTS
Sorry for the late reply. I realize this is an old post. In the future hope you don't have any vehicle issues, but, if you do keep the site in mind. They are always working to improve the site. They are beta testing a new site at the moment, lots of information.
To answer your question, I saw everything you replaced, didn't see any testing listed, did you do any testing before replacing all those parts?
If no spark, have to check voltage and ground for coil pack, go from there. At the fuel injectors have to check voltage and ground, check fuel injector pulse.
Were there any applicable trouble codes, before you replaced all those parts?
What about your security system?
Dec 7, 2015 at 2:20 AM
