Manual transmission fluid
FORD
STARMAN
I have a 1980 Ford F-100 pickup with a 3 speed manual transmission. What type of transmission fluid should I use if replacing? Standard transmission fluid or is there some special type for manual transmissions?
Jan 18, 2006 at 3:13 AM
LOVESCARS
  • 359 POSTS
Type F if your vehicle requires trans fluid. your auto parts person should be able to assist you with choosing the correct fluid or check your owners manual
Jan 18, 2006 at 6:16 AM
