I replaced the cv joints, axles,boots, etc. The front end still knuckles when i steer. Whetre is this noise coming from?
Mar 27, 2006 at 11:14 AM
SKBCHILD
MEMBER
i have a 1995 acura integra 4 door with 225000kms.it is properly maintained but lately its been running very low on oil.the oil is not burning off in the form of blue smoke nor is it leaking.all i know is that i have to keep checking it regularly.what is the problem with it???
Feb 25, 2006 at 1:02 PM
GODBEAR839
✓Experienced Mechanic
Could be ball joints,tierod ends,power steering rack or related components,loose brakes
You will have to climb under the front and start seeing if any of the parts are loose or not.
