ignition rotor problem
FORD
JONS89PGT
  • 8 POSTS
what's the worse thing that can happen if I reinstall the rotor in the wrong position? Old one was beat up and got a replacement rotor and cap but am not sure how it goes back...
thanks
Mar 14, 2007 at 4:11 PM
TAURUSWHEEL
  • 718 POSTS
The rotor is keyed, it'll only go back one-way. You need to make sure you re-install the sparkplug wires correctly to the cap, each has it's own place.
Mar 15, 2007 at 4:04 PM
JONS89PGT
  • 8 POSTS
thanks
got everything back on correctly.
The plugs were really hard to get out.
I put a small amount of dielectric grease on the threads, normally I'd use lithium grease but I couldnt find it. DO you think dielectric grease would be ok?
Mar 16, 2007 at 6:44 AM
TAURUSWHEEL
  • 718 POSTS
Yeah, that should be fine.. also supposed to use the grease around the sparkplug where it fits into the boot, what I usually do is just squirt a bit into the boot end also a small film on the tip of the rotor... I use a small amount of anti-seize on the threads myself...
Mar 16, 2007 at 10:32 AM
