1995 Ford Escort No Start After TPS
FORD
ASNO
If installing a throttle position sensor do you have to reset your computer.....and if so what happens if you don't.......also how can you tell if you have a bad sensor.....like if you bought a new one, is there anyway you can test it?
Feb 2, 2006 at 8:12 AM
LOVESCARS
  • 359 POSTS
Need more info year model, engine why do you suspect TPS? Symptoms? May be able to provide you some answers with more.
Feb 2, 2006 at 10:51 AM
ASNO
its a 1995 ford escort i got a computer scan done it said my throttle position sensor was gone so I replaced it then it worked and two mins later it died and now won't even start, with the old one it would start but have no power and if you stomped on the gas it would bog out, anyway i hope this helps
Feb 2, 2006 at 12:19 PM
LOVESCARS
  • 359 POSTS
did you disconnect the negative terminal on the battery to clear the code
Feb 2, 2006 at 1:01 PM
ASNO
I disconnected the positive does it make a difference?
Feb 2, 2006 at 1:03 PM
LOVESCARS
  • 359 POSTS
shouldn't time frame should be around 10 mins minimum. You may need someone to adjust the computer with the proper equipment.
check your catalytic converter as well hit it with the side of you hand to listen for any loose peices inside
Feb 2, 2006 at 1:06 PM
Suggested Repair
Disconnect the battery for at least 10 minutes to clear stored codes; positive or negative terminal should not matter. If the no-start continues, have the computer adjusted with proper equipment. Also tap the catalytic converter and listen for loose pieces inside.
Conversation Summary
The owner of a 1995 Ford Escort replaced the throttle position sensor after a scan indicated it had failed. The car ran briefly, then would not start; with the old sensor it started but had no power and bogged under hard throttle. The expert advised clearing codes by disconnecting the battery for about 10 minutes, said positive versus negative should not matter, suggested the computer may need adjustment with proper equipment, and recommended checking the catalytic converter for loose internal pieces.
