HOW DO U CK. FOR RESTRICTED CAT???
FORD
TAURUSWHEEL
  • 718 POSTS
I'm thinking a vacuum\pressure tester is used, in conjunction with a voltmeter, not quite sure what the order or series of tests consist of..
Dec 30, 2006 at 6:40 AM
TAURUSWHEEL
  • 718 POSTS
ABADAY
  • 38 POSTS
use a vacuum gauge and hook it up to intake vacuum the reading should be steady around 17 to 20 in then hold the rpm up to around 2500-3000 and hold it there for about three minutes if the gauge drops to low vacuum and dosent recover you have a restriction
Dec 30, 2006 at 11:46 AM
CNCGURU777
HOW???
Dec 30, 2006 at 12:21 PM
