how do i depress the rear brake piston to replace pads
FORD
CHARLESWPIXLEY
MEMBER
1 POST
2005 ford frestyle 3L V6 40000 rear brake pad change
Apr 25, 2007 at 6:52 AM
BOOTDOG
✓Experienced Mechanic
if the emergency brake cable goes to the caliper, then you'll need a special tool to push and twist the piston in. if the cable goes to the backing plate then you can push the piston in with a c-clamp.
