1989 Ford Horn Won't Work
FORD
DIANA
ford XR3i - 1989 - 90 000 miles
the horn was super sensitive and would sound when my sleeve brushed over it and now it won't depress in or make a sound there is nothing in my manual for fhe steering wheel side of things, could anyone help out a damsel in distress?
Dec 3, 2006 at 2:08 AM
BRUCE HUNT
  • 3,754 POSTS
There are a few things to look at. Fuse first, then under the hood check the wiring to the horn and check the ground. If it is a one wire horn the unit itself must be grounded and grounded cleanly. After that you can try a wiring short cut from the battery to the horn to get it to beep. This would serve as a test to see if the ground is good and that the horn itself is working. If you get the horn to honk then all of the problems will located in the steering wheel. Switch, wiring, etc.
Good luck
Dec 3, 2006 at 4:04 AM
Suggested Repair
Check the horn fuse, then inspect the under-hood horn wiring and ground. A one-wire horn must be cleanly grounded. Briefly jump battery power to the horn; if it sounds, the horn and ground are good and the fault is in the steering wheel switch or its wiring.
Conversation Summary
The owner of a 1989 Ford XR3i said the horn used to sound from a light brush and now will not depress or sound, with no steering-wheel guidance in the manual. The expert advised checking the fuse, horn wiring, and ground, then jumping battery power to the horn. If the horn sounds, the remaining fault is in the steering wheel switch or wiring.
