reset the fuel pump
FORD
TAURUSWHEEL
  • 718 POSTS
Usually the inertia switch is located on the right rear quarter panel behind an access panel or small door, depending on car,, sometimes you must remove a trunk trim panel to access it,, it's usually near the side marker light, or in front of the tailights.. push the button on top to reset, why would you need to do this, did you hit or be hit hard enough to trip this switch???
Apr 15, 2007 at 11:39 AM
2CP-ARCHIVES
  • 4,540 POSTS
Where is the fuel pump shut off switch on 1991 ford probe LX
THANK YOU
Apr 15, 2007 at 1:24 PM
2CP-ARCHIVES
  • 4,540 POSTS
I found the switch. Its all rusted and a wire broke off. The hatch leeks when it rains and it was in water.Im going to change it to see if it will run.It was shuting off now and then.I parked it for two years then started to run it again was running fine then shut off again.Thanks for the help.
Apr 17, 2007 at 2:52 PM
