Gear Oil
FORD
ANTHONY-FIESTA
Ford fiesta, 1995, 165,000 miles, I replaced the left hand drive, or crank shaft I think you Americans call it, I allowed all the gear oil to drain but now can't find where to put it back in. I know the gear oil goes in somewhere by the selectors, but I just can't find the selectors. If you answer my question I will link you on my website-www.revive.bravehost.com Thanks!
Jan 28, 2007 at 9:31 PM
SERVICE WRITER
  • 9,123 POSTS
I'll see what I can learn me on this one. Crankshaft is in engine, sounds like your in the transmission?
Jan 28, 2007 at 9:56 PM
CARUNDELL
  • 602 POSTS
Hey Anthony,
This one looks like a pain to fill! You have to remove the speedometer cable and then the speedo drive unit to fill it to spec. Let us know!
Chris
Jan 28, 2007 at 10:13 PM
ANTHONY-FIESTA
[quote:a51b5a0c68="Service Writer"]I'll see what I can learn me on this one. Crankshaft is in engine, sounds like your in the transmission?[/quote:a51b5a0c68] Thanks for your advice but my problem has nothing to do with the tranmission, It was the left hand drive kit I replaced (the bar going from the gearbox to the wheel) All I should have to do is take out an allen key screw and and pump in the gear oil.
Jan 28, 2007 at 10:57 PM
CARUNDELL
  • 602 POSTS
[quote:f67f3030d7="Anthony-Fiesta"][quote:f67f3030d7="Service Writer"]I'll see what I can learn me on this one. Crankshaft is in engine, sounds like your in the transmission?[/quote:f67f3030d7] Thanks for your advice but my problem has nothing to do with the tranmission, It was the left hand drive kit I replaced (the bar going from the gearbox to the wheel) All I should have to do is take out an allen key screw and and pump in the gear oil.[/quote:f67f3030d7]
Hey,
It seems we have a component description anomaly here. Did you change the "cv axle".? (That would be the drive axle) on the left side
Chris
Jan 28, 2007 at 11:05 PM
ANTHONY-FIESTA
Thanks for your advice but the speedometor cable is no where near the gear selectors, it is beside the gear selectors that the gear oil should go in.
https://images.2carpros.com/forum/automotive_pictures/56452_2631504019a3005179289b562783688m1_1.jpg
Jan 28, 2007 at 11:06 PM
ANTHONY-FIESTA
Thanks for your advice but my problem has nothing to do with the tranmission, It was the left hand drive kit I replaced (the bar going from the gearbox to the wheel) All I should have to do is take out an allen key screw and and pump in the gear oil.[/quote:929ba297c9] Hey, It seems we have a component description anomaly here. Did you change the "cv axle".? (That would be the drive axle) on the left side Chris[/quote:929ba297c9] I've being looking through the form and seen "cv axle" come up a lot but I have never heard of it before, I'm from Ireland, You should be able to understand what I mean by "drive shaft" its the bar that turns the wheel. When you take it out gear oil comes out of the gearbox, it is this gear oil I need to replace.
https://images.2carpros.com/forum/automotive_pictures/56452_2631504019a3005179289b562783688m1_2.jpg
Jan 28, 2007 at 11:12 PM
SERVICE WRITER
  • 9,123 POSTS
Were just having a hard time with your accent. :lol:
Jan 29, 2007 at 8:42 AM
