Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Other
Fuel System
Fuel Filter
Replace/Remove
fuel filter
FORD
STIPK212
MEMBER
1 POST
2002 mercury sable ls 3.0 duratec 55,000mi. where is the fuel filter located?
Apr 27, 2006 at 11:43 PM
TODDBWEAVER
MEMBER
Did you ever get an answer? I'm looking for mine on a 2002 Ford Tarus. Should be the same place on both.
May 20, 2006 at 3:56 AM
AHAWKFAN1
MEMBER
look under the car driver side along the inside of the frame.usually around or eved w/the drivers door.hope this helps.
Jun 3, 2006 at 4:50 PM
Add image or video
Ask a new question
Engine won't start
Engine misfire
