1981 Ford F100 Front Brakes Locking
FORD
CATUAR
i own a Ford Pick up F100 1981,problem is the front brakes are locking up, already replaced whole calipers, clean the brake lines and purged them out, and still the problem continues, what else can i do? please help me!
Jul 6, 2007 at 2:35 PM
2CARPRO JACK
  • 11,533 POSTS
Could be the proportioning valve is stuck, causing full pressure to the fronts or absolutely none to the rears, causing the fronts to lock
Jul 7, 2007 at 1:31 AM
MERLIN2021
  • 17,250 POSTS
Any contaminants in the fluid? Oil? Any master cyl work latley?
Jul 8, 2007 at 1:54 AM
Suggested Repair
Check the proportioning valve for sticking that sends full pressure to the front brakes. Also inspect the brake fluid for oil or other contamination and check the master cylinder, especially if it was recently serviced.
Conversation Summary
The owner of a 1981 Ford F100 pickup reports front brakes locking up after replacing the calipers and cleaning and purging the brake lines. Experts suggest a stuck proportioning valve may be applying full pressure to the fronts, and ask whether the fluid is contaminated with oil and whether the master cylinder was recently worked on.
