Engine control module
FORD
JBOLEN
Where is the engine control module on a 2001 Lincoln Town car?
May 17, 2006 at 9:36 PM
MOONLITCOYOTE
I cant say that I'm 100% sure but all the cars I have had the ECM or electronic control module is located behind or above the glove box. If you take the glove box out you should see a silver box. Which is the ECM. Hope I helped.
May 20, 2006 at 12:16 PM
JBOLEN
Thanks. I'll give it another look.
[quote:55a8349bbe="moonlitcoyote"]I cant say that I'm 100% sure but all the cars I have had the ECM or electronic control module is located behind or above the glove box. If you take the glove box out you should see a silver box. Which is the ECM. Hope I helped.[/quote:55a8349bbe]
May 20, 2006 at 2:23 PM
