brake drum rear
FORD
PEPPERONE
  • 18 POSTS
as i said in my first post had these drums off at 50000 miles and they were extremly hard to get off & even harder to put back on. now have 61000 and at 50000 miles they had a 3/16 inch ridge on side that faces backing plate now i can not get drums past that ridge even if i retract shoes as fsr as they can go.is there a special puller i can get because they won't come off the regular way or can i just break drum with a 3 lb hammer .i belive drums are cast steel .any help would be great. thanks pepperone
Jul 5, 2007 at 11:43 PM
PEPPERONE
  • 18 POSTS
i guess i was stupid not changing at 50000 miles. but got new drums new hardware new shoes & everything is okay it is the big ridge on the drums thats making then hard to get off so i guess i will drill the two retaining pins out & hope they will come off. ps the brake cable is loose the drums spin freely so its the ridge on drums.if i can't get them off by just drilling pins i will take wheel cylinder off & just bleed system. thanks for your help. pepperone just wanted to say i got drum off i sprayed some wd40 on star adjuster wheel waited about 1/2 hour & got shoes to retract & drum came off pretty easy.but when went to replace every thing shoes- hardware- & new drum had to have starwheel retracted all the way or new drums would not go on.but got it off thanks again for your help pepperone
Jul 6, 2007 at 10:29 PM
