1998 Ford Taurus SE Surges in Drive
SymptomsYou may notice drivability problems such as the engine may surge off idle. There may also be other symptoms.
CausesA code P0402 most likely means one or more of the following has happened:
The DPFE (differential pressure) sensor is faulty and needs to be replaced
There is a blockage in the EGR (most likely carbon buildup)
The EGR valve is faulty
The EGR valve may not be opening due to a lack of vaccuum
Possible Solutions With a P0402, it is common for people to replace the EGR valve, only to have the problem return. The most likely solution is to replace the DPFE sensor.
Check the voltage at the DPFE sensor both at idle and when the EGR is open
Replace the DPFE sensor"
The above is a more technical answer. The shorter story is that ehaust fumes are sucked into the engine to lower pollution. The passage from the exhaust to the engine intake is important also. Some time on higher mileage vehicles soot from the exhaust builds up and will not let the valve close. It is only supposed to be open when the engine is running fast.
The least expensive repair might be to simply clean EGR the port and valve with carb cleaner and an old toothbrush.
Ford has had problems with their DPF sensors. These let the computer know what is going on with EGR flow. The will fail and give false information. The computer then does things it shouldn't. This would be the next thing I would test and/or repair/replace.
Good luck and let us know. :)
Suggested Repair
Confirm the P0402 excessive EGR flow code. Clean carbon buildup from the EGR valve and ports with carburetor cleaner. If the surge continues, test and replace the DPFE sensor, a common Ford failure that can cause false excessive-flow readings. Also verify the EGR valve is not stuck open and has proper vacuum.
Conversation Summary
The owner of a 1998 Ford Taurus SE with a V6 and automatic transmission reported a service engine light and surging or jumping in drive without pressing the accelerator. Codes showed excessive EGR flow (P0402). The expert explained that the EGR system recirculates exhaust to control emissions and that a faulty DPFE sensor, carbon blockage, or a sticking EGR valve can cause off-idle surge. Recommended steps were to clean the EGR valve and ports, then test or replace the DPFE sensor.
