2009 Other Ford Models removing ignition
2009 FORD
200,270 MILES • 4 CYL • FWD • AUTOMATIC
GARLIZ
we want to replace ignition lock but dont know how to remove can you help,ford econo van 2000 model
Mar 14, 2009 at 6:35 PM
BILLYMAC
  • 2,204 POSTS
hi if you have the key not that bad. turn key on push pin located directly under key through small hole in plastic pull out.. if you don,t have key use punch and hammer punch this pin out pull lock out
Mar 30, 2009 at 9:00 AM
