we want to replace ignition lock but dont know how to remove can you help,ford econo van 2000 model
Mar 14, 2009 at 6:35 PM
BILLYMAC
✓Experienced Mechanic
hi if you have the key not that bad. turn key on push pin located directly under key through small hole in plastic pull out.. if you don,t have key use punch and hammer punch this pin out pull lock out
Mar 30, 2009 at 9:00 AM
