2001 Other Ford Models HEADLIGHTS
2001 FORD
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
RANGER1957
WHEN I PUT THE SWITCH ON HIGH BEAMS, THEY DONT COME ON AND NEITHER DOES THE DASH ICON, BUT MY LOW BEAMS WORK. SO THE HIGH BEAM SWITCH LEAVES ME IN THE DARK, LITERALLY. I HAVE CHANGED THE BULBS, EVEN THOUGH THEY APPEARED TO BE FINE. I HAVE CHECKED ALL THE FUSES AND RELAYS FOR CONTINUITY. THEY SEEM FINE, ANY SUGGESTIONS
THANKS
VIC
Apr 28, 2008 at 8:49 AM
MASTERTECHTIM
  • 4,750 POSTS
most likely the culprit is the multi function switch in the steering column. correction, it has to be the multi function switch
Apr 28, 2008 at 9:47 AM
