2000 Other Ford Models One coil spring broken - what to repl
2000 FORD
CECILE.DUBLIN
Suspension problem
2000 Other Ford Models Manual
I have a Ford KA with the coil spring broken on the driver side (failed NCT). The NCT mechanic told me to replace it and re-test the car.
My garage is saying that:
- I should replace both springs at the front because replacing only one would cause an imbalance
- I should also replace both shocks because it's not good to have new springs and old shocks
Could you confirm that I need to replace all of this? It would cost me 380 euros, which is a big deal for me to pay to I'd like to make sure it's essential...
Thanks a lot!
C
May 6, 2008 at 10:34 PM
  • 31,937 POSTS
Hi there,
I would be replacing the springs as a matched set only, if the struts are ok, leave them alone.
mark (mhpautos)
May 6, 2008 at 10:39 PM
