2000 Other Ford Models Motor
2000 FORD
62,000 MILES • 4 CYL • FWD • AUTOMATIC
MERRYCONKLIN
Can a 2000 Ford Concorde motor fit in any other Ford car? I have a motor with a bad body so I am looking for another car to put this motor into it. Is this possible if so can you tell me. Thank-You, Merry
Jun 4, 2010 at 2:03 PM
HMAC300
  • 48,601 POSTS
the motor will go in any car that is similar, meaning if it's a front wheel drive car it has to go in a front wheel drive car. If it's a rear wheel drive motor then it has to go into the same. You should go for a same type of car though that has the same engine size, like 4.0L or 3.8L etc. you may have to change the engine dress- meaning alternator/compressor/starter/ brackets. Also you want to stay with the same size due to the computer.
Jun 8, 2010 at 11:02 AM
