1999 Ford ZX2 Overheating and A/C Shutoff
1999 FORD
ALLBRATS
My car tempurature has been running a little higher than normal and the A/C then shuts off. I just bought this car and I think its the radiator fluid being so dirty. Could that be the problem?
Aug 7, 2006 at 9:42 AM
MIKEYBDMAN
  • 623 POSTS
[quote:e297401b7f="allbrats"]My car tempurature has been running a little higher than normal and the A/C then shuts off. I just bought this car and I think its the radiator fluid being so dirty. Could that be the problem?[/quote:e297401b7f]
If your airconditioning is cutting off, then that may be the problem for the slight overheating. I would get the a/c serviced and see if that corrects the problem.
Aug 7, 2006 at 10:14 AM
Suggested Repair
Have the air conditioning system serviced. The expert indicates that the A/C cutting out may be causing the slight overheating and recommends checking whether A/C service corrects it.
Conversation Summary
The owner of a 1999 Ford ZX2 reports that the engine temperature runs a little higher than normal and the A/C then shuts off, and suspects dirty radiator fluid. The expert says the A/C cutting off may be causing the slight overheating and recommends having the A/C serviced to see if that corrects the problem.
