1998 Other Ford Models
1998 FORD
111,000 MILES • 4 CYL • FWD • MANUAL
MCMITCH123
hi i have a ford courier van 1.8d 1998 the problem is when the engine is turned off and key removed the engine keeps on running for about 3 mins then turns off. the immboliser to the van has been disconected. any ideas
Feb 26, 2009 at 5:47 PM
DAVE H
  • 13,383 POSTS
you must have an electrical fault somewhere ... I would try checking the ignition switch first ... this should cut all power when in the off position ..
Feb 26, 2009 at 11:40 PM
